Difficult Engaging 2nd Gear
Postby Dave MacPherson » Thu Feb 27, 2020 10:11 am
This has been my first winter with my Mk3.5 and I’ve noticed difficulty engaging 2nd gear until the car warms up. I’m assuming that this is just a feature of the MX5 and that I’m not alone? The car has only done 27,000 miles and regularly serviced by Mazda, so I would expect the correct gearbox oil to have been used.
Dave
Dave MacPherson
David MacPherson
Re: Difficult Engaging 2nd Gear
Postby drumtochty » Thu Feb 27, 2020 2:23 pm
The oil specified by Mazda will have been used. It has been found that certain oils that meet the specification are better than others at startup.
See my other post.
Postby Dave MacPherson » Sat May 09, 2020 9:37 am
I finally got around to replacing gearbox and diff oils. I used the Redline MT90 GL4 in the box and the GL5 in the diff.. The old oils looked relatively clean and I can't say I've really noticed much of an improvement changing gear, particularly engaging 2 gear. I'll get around to changing the turret oil sometime.
Dave MacPherson
David MacPherson
Postby drumtochty » Sat May 09, 2020 2:43 pm
Some cars are better than others and some just do not improve no matter what.
Clutch adjustment from inside the car. Google for a guide
Check and if needed replace the clutch slave cyliner if leaking
Postby Dave MacPherson » Wed May 13, 2020 8:18 am
Many thanks
Dave MacPherson
David MacPherson
Users browsing this forum: No registered users and 18 guests
