4 Wheel alignment ayrshire
Postby Delboy69 » Fri Oct 12, 2018 7:20 pm
Anyone have any recommendations for 4 wheel alignment in Ayrshire or nearby and and approximate cost?TIA
Delboy69
Re: 4 Wheel alignment ayrshire
Postby OldSpice » Fri Oct 19, 2018 12:11 pm
Not having a lot of luck are you?!
Short answer is a no from me however I can recommend the well known & respected Pro-Grip 12 Central Park Ave, Larbert FK5 4RX.
Best suggestion I can muster is pick a weather-watched day to book in, and let John work his magic.
At least you could use some of the epic roads home to "test".
Postby Delboy69 » Sat Oct 20, 2018 5:52 pm
Lol yeah it looks like that,i should have changed it to Ayrshire/west coast or anywhere lol
Thanks for the recommendation,i don't mind travelling and as you say would be a chance to road test it on the way home :D
Delboy69
Postby OldSpice » Sun Oct 21, 2018 1:28 pm
Well I'm local and retired so it's entirely possible I can meet you there and whip you over to an adjacent Garden Center for a coffee while it takes John his usual hour.
There's nowhere for you to go.
Let me know.
Postby gm » Sun Oct 21, 2018 5:51 pm
dreadnought up in Callander will do a good job and it's a nice drive up there.
or clcm in edinburgh ?
Postby Delboy69 » Sun Oct 21, 2018 10:37 pm
Thanks for the offer oldspice,once i sort a few things and get some time i might just take you up on your kind offer,you have any idea how much it is for the alignment?
Thanks gm it is indeed a nice drive up that part of the country so another good shout
Delboy69
Postby OldSpice » Mon Oct 22, 2018 3:40 pm
Delboy69 wrote:Thanks for the offer oldspice,once i sort a few things and get some time i might just take you up on your kind offer,you have any idea how much it is for the alignment?
TBH, it can vary but I'd budget between £60/£70 quids tops.
Frankly, given so much of the "speed being in the chassis" with our cars, I've always considered laser an important "modification"
Postby Delboy69 » Tue Oct 23, 2018 7:00 am
Defo something i think that needs done as had it out and about a couple of times and felt the back end even just going over small bumps felt a bit 'twitchy' even though i wasn't pushing it so certainly wont do any harm getting it checked out
Delboy69
Postby OldSpice » Wed Oct 24, 2018 7:53 am
Could be a number of things eg tyre "mix" & pressures , the common enough one being duff drop-links, or even tired bushes/shocks depending on age & condition.
Without being alarmist, a cracked spring can hide it's sins as they can go at the seating.
Ask me how I know. :shock: These 5 chassis are unforgiving insofar they are either right on the button, or "not very good"!
Anyhow a ramp session by an expert is the best way forward.
Postby Scott_J » Wed Dec 19, 2018 7:51 pm
Kenneth Brown Engineering, Hillington, set my NC up beautifully to fast road spec .
Scott_J
