MK4 Window Trim Rust
Postby Terryk7 » Tue Aug 21, 2018 10:35 pm
Hello all,
I have found a little bit of rust on my Window Trim (2017 Sport Nav) I have taken it to Mazda & they have been informed of this fault & have a new Modified part to fit to both sides even tho I only have rust on the drivers side they are replacing both. Check you MK4 for rust on the Window trim as this is rubbing against the Piller & causing it to rust.
MK4 Side Window Runner
MK4 Sport Nav 1.5 (Skyler)
Terryk7
Terry Kiernan
Re: MK4 Window Trim Rust
Postby Terryk7 » Thu Aug 23, 2018 12:11 pm
Just got back from Mazda, 2 hours to replace both sides
Side Runner Fixed
Terryk7
Terry Kiernan
