MK3 Oil pressure Gauage Movement
Postby gwalker » Tue Mar 14, 2017 11:35 pm
Hi
Just sold my Mk2.5 after nearly 9 years, now have a Mk3 2ltr Sport.
The Oil pressure gauge of my Mk 3 moves with change in speed, increases (to the right) with speed and reduces as you slow down(to the left).
Sometimes it stays in the middle, it does not however go out of the limits stated in the handbook. I ask this question because in my Mk2.5 the needle stayed in the middle of the dial always.
Is the movement related to speed normal with the Mk3 Sport?
Cheers Graham
gwalker
Graham Walker
Re: MK3 Oil pressure Gauage Movement
Postby IanN » Wed Mar 15, 2017 8:02 am
Hi Graham
This sounds normal, my old Mk 3.5 did that from new.
As mentioned on this post: viewtopic.php?f=6&t=11147&p=80889&hilit=Mk3+oil+pressure+gauge#p80889
2016 Mk4 Icon Special Edition
IanN
Ian Ness
Postby Snapper Mike » Thu Mar 16, 2017 1:34 pm
My MK3.5 Sport Tech behaves exactly in the same way.
MK3.5 2.0L Sport Tech, Stormy Blue.
Snapper Mike
Mike Wilkinson
Postby sclements » Fri Mar 17, 2017 3:33 pm
The mk2.5 oil pressure gauge wasn't a true gauge more a switch hence its fixed position in the middle, sounds like they have gone back to a proper one which will rise and fall and is normal.
Although it probably electronic now and controlled through the ecu.
Scott
sclements
Postby gwalker » Sat Mar 25, 2017 9:34 pm
Hi All
Many thanks makes sense.
Graham
gwalker
Graham Walker
