Rika
Re: Project Rika
Postby iainf » Mon Jan 16, 2012 10:28 pm
John H wrote:Ah, all is clear. I have used Jim and Julian at Turriff for years, great place. :wink:
second that.
Iain Fleming
National Events | Branding, Press & PR | Merchandise www.mx5oc.co.uk/store
iainf
Iain Fleming
Re: Project Rika
Postby eharwood » Tue Jan 17, 2012 10:42 pm
Really inspiring stuff, wish I had the confidence to have a go at all these kind of things! Top work!
eharwood
Re: Project Rika
Postby sarahlc » Fri Feb 03, 2012 3:19 pm
I have got a couple of small bits and pieces done recently, Firstly I replaced the chrome door mirrors with the some silver ones, Chrome is not my taste.
the other thing I got done was to replace the Interior mirror as the old one had tarnished around the edges, its details like this that really bug me.
Top is the replacement and below show the old one with the tarnished edges on the glass.
sarahlc
Sarah Close
Re: Project Rika
Postby Rossnmo » Fri Feb 03, 2012 5:28 pm
Could you tell me where you got your remote locking kit for your car and is it simple to fit?
Our Eunos locks are becoming so sticky it's going to cost a fortune in replacement keys.
Your car looks good in its original trim.
1992 1.6 Roadster in Black'n'Tan
Confucious says:
"A journey of a thousand miles begins by taking the hood down"
Rossnmo
Re: Project Rika
Postby drumtochty » Fri Feb 03, 2012 10:57 pm
Rossnmo wrote:Could you tell me where you got your remote locking kit for your car and is it simple to fit?
Stop the bus and let's think this through.
Your locks are getting sticky and let's say getting worse.
You fit a remote locking kit and say six months later your car battery fails on your car when locked.
You cannot get the remote locking working to open the car and as you did not fix the sticky locks the keys will not work.
So two problems here.
You need the manual system to be working well before fitting a remote system, so either get the locks lubricated, repaired or replaced and would it be the end of the world if the door locks were on a different key to the ignition. So saving cost.
This secondhand set is cheap.
http://www.ebay.co.uk/itm/Mazda-MX5-Mk1 ... 256c01f030
New key cut here
http://www.mazda-mx5-shop.com/index.php ... ducts_id=4
If you search on ebay for MX5 remote locking there are plenty of kits there from about £30.
Re: Project Rika
Postby sarahlc » Mon Feb 06, 2012 12:39 pm
Yesterday I got my fog light switch replaced with one of these http://www.mx5parts.co.uk/light-switch-p-129.html
Its quite expensive for what it is.
The current switch was a very cheap thing hanging from the dash, looking rubbish.
The new switch looks so much better, I just need to find a Rubber blanking grommet to fit in the hole left by the old switch, having trouble finding one of the right size at the moment. I also think its a shame that Mazda decided to go with a more matt finish that the older blanking plugs.
sarahlc
Sarah Close
Re: Project Rika
Postby sarahlc » Thu Apr 05, 2012 3:45 pm
Over the last couple of days I got the front suspension apart again in order to replace the lower from ball joint boots, the joints them selves were in good condition as the boots had only just started to split.
The old boot was leaking some very dirty looking grease.
With the old boot removed, the old grease cleaned out and replaced with nice fresh stuff, a new boot pushed in to place.
On the front offside I had a leaking damper, so I replaced it with a second hand one from Autolink. At some point I will get the whole suspension replaced with probably Koni Sports, but I don't have the funds at this time to do it, so this will do for now.
At the same time I replaced the bump stops/boots as they were just a pile of little rings around the damper shaft.
sarahlc
Sarah Close
Re: Project Rika
Postby Colin & Margaret » Thu Apr 05, 2012 6:14 pm
sarahlc wrote:I just need to find a Rubber blanking grommet to fit in the hole left by the old switch, having trouble finding one of the right size at the moment.
Why not buy one that is as close as possible but slightly bigger than you need then just enlarge the hole to fit?
2002 1.8 Silver Sport - Now gone too a new home..............
2010 2.0 Aluminium Silver Sport Tech - Getting on but still enjoying the wind in my skin!!
Colin & Margaret
Re: Project Rika
Postby sarahlc » Thu Apr 05, 2012 6:49 pm
I found one that fit.
sarahlc
Sarah Close
Re: Project Rika
Postby sarahlc » Sun Apr 08, 2012 7:35 pm
Got a few things done over the last couple of days.
I fitted new Shift lower and higher boots, got the nylon cup at the bottom of the gear lever replaced, and changed the oil in the turret. I also changed my fuel filter, removed one of the rear tie down hooks, and painted the front ones up in some black Hammerite.
I also got IL Motorsport front and rear Chassis braces fitted.
Rear Brace
Front Brace
I think between the chassis bracing and the new gear lever bits she will drive quite a bit better, just how much better I will find out tomorrow :D
sarahlc
Sarah Close
Re: Project Rika
Postby sarahlc » Tue Apr 17, 2012 10:23 pm
Today I finally finished my DIY refurb of my OZ's by applying the decal to the centre caps, I think they have come out quite well.
sarahlc
Sarah Close
Re: Project Rika
Postby IanN » Wed Apr 18, 2012 10:23 am
Your cars looking great Sarah it's 8)
2016 Mk4 Icon Special Edition
IanN
Ian Ness
Re: Project Rika
Postby Kirky007 » Thu Apr 19, 2012 8:16 pm
Sarah, your car is really looking the business now. No one has mentioned much reference to your wheels but as nice as the OZ's are in the last pic, I much prefer the car wearing the Minilite style in the very first batch of pics. I think that wheels absolutely make or break any car in the looks department. Just on a finishing note and I feel no one will agree but the original Mazda minilite things look awful on any colour of '5 but good for having winter boots on I suppose.
Kirky007
Re: Project Rika
Postby sarahlc » Sat Apr 21, 2012 12:10 pm
Kirky007 wrote:.....No one has mentioned much reference to your wheels but as nice as the OZ's are in the last pic, I much prefer the car wearing the Minilite style in the very first batch of pics. I think that wheels absolutely make or break any car in the looks department.
The Picture with the RB's are of the same car, they were changed to the OZ's, and I made a couple hundred quid from the sale of the RB's, over and above the price of the OZ's.
Now I would agree perhaps the Rota RB's do perhaps look better than the Oz's on the my car, but thats down to personal opinion. Now I'm not saying for a second here that the OZ's are my definitive wheel choice, as I will probably replace them in a few years time with something different. However for now they are a great wheel, that I picked up for not a lot of money.
So why did I change, well there are multiple reasons.
The RB's were 15 x 8 with a offset of 30 and weight without tyres is 6.3kg each. They had 195/50 section budget performance tyres on, which on a 8in wheel meant stretch. Whilst I did think about changing to larger section tyres, they are much more expensive than 195 tyres and of course would also increase unsprung weight. I don't personally like the stretch tyre thing, I find it interesting that the maximum wheel width that toyo recommend for the 195/50/15 tyre is 7in.
Now the OZ superleggera wheels are 15 x 7 with an offset of 38 and weight without tyres is 5.2kg each. These came with a set of good Toyo T1R 195/50 already mounted. So no tyre stretch and a unsprung/rotational weight saving of 1.1kgs per corner (even more if you consider I would of gone with a wider tyre on the RBs). The effect of increased unsprung weight on these cars is well known. There is a very minor benifit to the higher offset number, as this keeps the Scrub Radius closer to what the Mazda engineers intended.
So in conclusion with the change, I got wheels that are lighter, better suited to the cars suspension, better tyres with no stretch and I made a couple hundred quid. So many people make their choice of wheel on looks alone, when there is much more to be considered.
sarahlc
Sarah Close
Re: Project Rika
Postby Richardn » Sat Apr 21, 2012 1:39 pm
I think you did the right thing selling the wheels, they look fine on a Yellow car
Re: Project Rika
Postby sarahlc » Sat Apr 21, 2012 2:01 pm
Richardn wrote:I think you did the right thing selling the wheels, they look fine on a Yellow car
Yes they do :D
sarahlc
Sarah Close
Re: Project Rika
Postby Kirky007 » Tue Apr 24, 2012 2:47 pm
You are absolutely right, there is more to choosing wheels than just looks. I wasn't aware that the original pic had extreme sizes of wheel tyre combination etc. I naturally assumed that any wheels you would have on or fitted would have been optimum for chosen purpose. Although many have been caught out , just because the PCD is the same. Getting back to looks, it is all personal no doubt. I was just saying that my view was such, they did look good eh?
Kirky007
Re: Project Rika
Postby sarahlc » Tue Apr 24, 2012 11:35 pm
Kirky007 wrote:..... they did look good eh?
Yes they did look good, they now look even better on Richards MK1 Californa :)
Over the last couple of days I got a few things done.
I continued to tidy up the engine bay some more.
I got out my welder and modified the diagnostics plug bracket so that it sits in a less prominent position, but is still easy to access
Whilst my welder was out a also modified the fuse box bracket so that the igniter could be repositioned, allowing for complete removal of its bracket.
The engine bay is now looking a bit better than it was when I got the car, there are other bits I want to paint up and make it look even better, but that will have to wait as I am starting a new job in a few days time.
sarahlc
Sarah Close
Re: Project Rika
Postby 1600eunos » Wed Apr 25, 2012 6:58 am
Hi Sarah, did you receive my PM?
Stewart
1600 Eunos
1800 Eunos - 1994.
1600eunos
Re: Project Rika
Postby happypetsservices » Mon May 14, 2012 9:33 am
Hi,
I've just bought a 1995 mk 1 and brought it back to Scotland from Middlesborough yesterday.
The rear screen is very opaque, what do you reccommend to clean it?
I have some Pro Marine, Rib Shine from my boat but not sure that is the best option
Chris
email: happypetsservices@yahoo.co.uk
1995 Classic Red 1.8is.
happypetsservices
PreviousNext
